Set certain fields in form to read mode in LCA
Solved1.33K views27th January 2025form LCA LCA Editor SetReadMode
Hari priya Venkatesan [DevOps Advocate]1.06K 19th September 2024 0 Comments
I have a form in LCA, during edit i want to disabled(read mode) the textbox values of only certain field. I can see there is option to set the whole form in read mode, i cannot find an option to set only certain fields in the form to read mode. Please let me know if it is possible
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th January 2025
Gerwin van der Kamp [DevOps Advocate]4.09K Posted 19th September 2024 1 Comment
This is possible when you add States, then you can have certain fields read-only while in that state.
Gelber Mahecha [SLC] [DevOps Enabler] commented 19th September 2024
To complement Gerwin’s answer, the DOM status system may be used here to achieve the goal. You can find the documentation here:
https://docs.dataminer.services/user-guide/Advanced_Modules/DOM/DOM_status_system.html
