Seperate DMA failover agents for critical control functions
Solved1.26K views22nd April 2024
Alex Peat145 1st February 2024 0 Comments
Is it recommended to use a seperate DMA pair to host elements that are used for critical control functions eg. live IP video switching or routing?  With the idea that this might reduce start up time for agents in a failover scenario
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 22nd April 2024
Bert Vandenberghe [SLC] [DevOps Enabler]9.75K Posted 1st February 2024 1 Comment
Hi Alex,
Yes, that’s definitely a good approach which I would also highly recommend. It will indeed reduce the startup time like you mention, and separating it might also bring benefits in maintenance because updates could be done less frequently on this system while you can run the latest version on another system with all the latest features available there.
So in general, a system for critical control indeed benefits from keeping it small and separate from other dataminer systems.
Bert
Alex Peat commented 1st February 2024
Hi Bert
Thank you. I hadn’t considered using a completely different DMS for control elements if I understand correctly – I thought that might add some challenges with multiple services containing elements from different systems.
Alex
