Sending “I’m going to stopped’ message to other element
Solved2.39K views17th September 2021driver inter element communication
Maxim Bouckaert [SLC] [DevOps Member]179 17th September 2021 0 Comments
Hey everyone
For a manager/node driver we want to do the following.
If the node is set to a stopped state, we want to inform the manager as soon as possible.
As of now, we do this by doing a check every x time from within the manager, but because there can be a lot of nodes running, we don’t do this a lot, giving a considerable delay.
Is there a way to have this node declare to the manager that it is going to a stopped state (a last trigger/another way to inform the manager)? Or is pinging the element from within the manager element the only way?
Wannes Wittevrongel [SLC] [DevOps Member] Answered question 17th September 2021
Robbie Demaegdt [SLC] [DevOps Member]666 Posted 17th September 2021 2 Comments
I had kind of the same question a few months ago.
https://community.dataminer.services/question/how-to-execute-an-action-when-element-is-getting-stopped/
Tom Van Bruaene [SLC] [DevOps Member] Posted new comment 17th September 2021
Maxim Bouckaert [SLC] [DevOps Member] commented 17th September 2021
Ah, indeed robbie. Thanks for informing me.
I have put a vote to the feature request.
Tom Van Bruaene [SLC] [DevOps Member] commented 17th September 2021
The workaround Miguel suggested with correlation should work in your case and be pretty straightforward, right?
Wannes Wittevrongel [SLC] [DevOps Member]169 Posted 17th September 2021 0 Comments
I think you can achieve this by subscribing to the element state of those nodes.
https://help.dataminer.services/development/DataMinerDevelopmentLibrary_Customer/part4ClassLibrary/CLASkylineDataMinerLibraryProtocolSubscriptionMonitors/ElementMonitorExtensions_methods.htm?rhhlterm=ElementMonitorExtensions&rhsyns=%20
