Send Header field with embedded webpage
Solved2.46K views12th July 2023embed Microsoft Visio Visio
Gerwin van der Kamp [DevOps Advocate]4.09K 30th March 2021 0 Comments
Is it possible to send a custom header to an in visio embeded webpage? Bit like the UseLoginCredentials but with a header ( to send a cookie or any other header)
Bert Buysschaert [SLC] [DevOps Advocate]5.32K Posted 30th March 2021 1 Comment
Hi Gerwin,
This is currently not supported, but should only be a minor feature request. For the use case you have in mind, would this HTTP header have a static value that can be saved in the visio document, or would it have to be a dynamic value?
Gerwin van der Kamp commented 30th March 2021
Hi Bert,
For starters it would be static, however if it can be dynamic it would be more flexible.
