Seeking Help: Hover-Based Element Information Display
Solved3.26K views20th October 2023Element Details Element Parameters element popup Hover Info Display
Nuril Kamarudin [DevOps Advocate]212 12th October 2023 0 Comments
I want to display specific parameters and info IDs, like an element's IP Address and Serial Number, when hovering the mouse pointer over the relevant element.
Currently, these details are always visible on the screen, but I prefer them to appear only when I hover the mouse pointer over the element. I've experimented with the 'Hover Target' and 'Info' parameters, but they seem to require manual input for both values, which can be time-consuming and potentially error prone.
I've attached some screenshots for reference, and in this example, I'm focusing on the HPA-V.
Appreciate any insights.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 20th October 2023
Nuril Kamarudin [DevOps Advocate]212 Posted 19th October 2023 1 Comment
I'm sharing my solution below for the benefit of others and welcome any suggestions or feedback. Please feel free to share your thoughts.
  • Add the following shape data and assign the value as shown below;
  • The output will be shown as follows when the mouse pointer hovers over the "info" icon, as indicated by the red arrow.
Steve Purcell [SLC] [DevOps Advocate] commented 19th October 2023
Hi Nuril, Nice approach, I never tried using the tooltip as the shape data field. This looks nice., thanks for sharing.
