Seeking Help: Hover-Based Element Information Display
Solved3.19K views20th October 2023Element Details Element Parameters element popup Hover Info Display
Nuril Kamarudin [DevOps Advocate]212 12th October 2023 0 Comments
I want to display specific parameters and info IDs, like an element's IP Address and Serial Number, when hovering the mouse pointer over the relevant element.
Currently, these details are always visible on the screen, but I prefer them to appear only when I hover the mouse pointer over the element. I've experimented with the 'Hover Target' and 'Info' parameters, but they seem to require manual input for both values, which can be time-consuming and potentially error prone.
I've attached some screenshots for reference, and in this example, I'm focusing on the HPA-V.
Appreciate any insights.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 20th October 2023
Steve Purcell [SLC] [DevOps Advocate]2.63K Posted 16th October 2023 1 Comment
Hi Nuril,  One way to accomplish this would be to:
  • Have a Visio page on the specific element(s) showing the data you want to show in the hover popup using Info or Parameter shape data.
  • Then on the View or higher-level drawing, add VdxPage shape data using the |tooltip display option.
  • If you do not want this page displayed on the element view, you use the options|hidden shape data at the page level.
  • Then when the 'Hover' shape is gone over with the pointer the system will display the element view referenced.
For more information in using VdxPage see - https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/miscellaneous/Making_a_shape_display_a_particular_page_of_the_current_Visio_drawing.html
Nuril Kamarudin [DevOps Advocate] Edited comment 19th October 2023
Nuril Kamarudin [DevOps Advocate] commented 19th October 2023
Hi Steve,
Thanks for taking the time to provide a solution to my question. Appreciate your help and the effort you put into assisting me. In the meantime, I was able to come up with a solution on my own as well. I thought I’d share it here; in case it might be helpful to others facing a similar issue.
