Scripting a certain function for a UIBlock Button in a C# Automation Script
Solved1.15K views23rd April 2025automation scipt C++ Cube UIBlock Button uiblockdefinition
Satrap Shojaie [DevOps Member]130 6th November 2024 1 Comment
Hello!
Is there a way to program a UIBlock Button in an Interactive Automation Script to run a certain code when pressed?
The intention is to avoid the uiResult.WasButtonPressed("destVar") way which requires a Do...While or if approach; so that the button can do what it's asked to while the main Async Task script is running.
Satrap Shojaie [DevOps Member] Selected answer as best 23rd April 2025
Jarno Lernou [SLC] [DevOps Enabler]5.79K Posted 6th November 2024 2 Comments
Hi Satrap,
The easiest way to get started with building an interactive Automation Scripts (IAS) is consuming the Interactive Automation Script Toolkit | DataMiner Docs.
You'll find quite some good content to get your started:
  • Getting started with the IAS Toolkit | DataMiner Docs
    • links to KATA: Kata #10: Create a simple interactive script - DataMiner Dojo
  • Blog Post on DOJO: Available now: Interactive Automation script example package - DataMiner Dojo
    • Example on Catalog
    • Source Code: SkylineCommunications/SLC-AS-Example_InteractiveAutomationScriptToolkit: Contains examples of interactive automation scripts that use the InteractiveAutomationScriptToolkit NuGet package.
All links provided are giving you information on how to do this, but it comes down to introducing a Button and adding an event handler to it.
Kind Regards,
Jarno
Satrap Shojaie [DevOps Member] commented 6th November 2024
Thanks a lot! If I’ve designed my automation script in the old fashion way of UIBLOCKDEFINITION, UIBUILDER and …, will there also be a way to accomplish this?
Jarno Lernou [SLC] [DevOps Enabler] commented 6th November 2024
Nowadays, we highly recommended using the interactive toolkit, but if you insist on using the raw available features, it is also possible although a little bit more complex. I would recommend you to watch the following video, where my colleague is showing how we used to develop interactive automation scripts. Interactive automation using C# – DataMiner Dojo (https://community.dataminer.services/courses/dataminer-automation/lessons/interaction-automation-using-c/)
