Scripted connectors “execution with result: ‘—-“
Solved1.42K views14th November 2024JSON Scripted Connectors
Ömer Eryaman [DevOps Member]723 11th November 2024 2 Comments
I have a prepared JSON file, and I’m trying to read it using scripted connectors, but I’m encountering the following error message:
[2024-11-11 12:47:09.410 INF]ScriptExecutor#78350387 finished script ‘Data Sources\Scripted Connectors\367f012b-1629-432b-98f1-ccbc67cb0c4a.py’ execution with result ‘——————————–
I’ve reviewed the limitations (e.g., the file is less than 1 MB and only involves JSON parsing). The logic is handled externally.
https://docs.dataminer.services/user-guide/Advanced_Modules/Data_Sources/Data_Sources_Limitations.html
Ömer Eryaman [DevOps Member] Selected answer as best 14th November 2024
Alberto De Luca [DevOps Enabler] commented 12th November 2024
Is that line the actual result you get?
Ömer Eryaman [DevOps Member] commented 13th November 2024
thanks for the comment,
yes correct i just realize it
after he should execute this :
session.put("http://localhost:34567/api/data/parameters", json=json_string, headers=header_params)
but nothing is showing in the dataminer
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.39K Posted 14th November 2024 1 Comment
Hi, it looks like you have a print statement in your python script and that’s the source of the ‘——‘ in the logs.
Can you check the same logs to see there are no errors indicated in your python script. That could cause no element to be shown in Dataminer.
Ömer Eryaman [DevOps Member] commented 14th November 2024
Hello, thank you for your response.
I checked, and unfortunately, no errors appear in the logs. It seems that the JSON could not be parsed to create the element; the JSON appears to be malformed.
I fixed it.
