Script Failure (Dom Editor) while using DomInstanceValueFieldDiscriptor
Solved3.38K views14th August 2023DOM DOM Editor
Ladan Razeghi [DevOps Catalyst]1.09K 25th April 2023 3 Comments
I'm using Dom Editor and while trying to link a field in one section definition to another section I receive this error.
Script Failure (Dom Editor): EXIT: "System.InvalidCastException: Unable to cast object of type 'Skyline.DataMiner.Utils.InteractiveAutomationScript.StackPanel' to type 'DOM_Editor_1.FieldDescriptor.Panels.DomInstanceValueFieldDescriptorPanel'.
at DOM_Editor_1.FieldDescriptor.PresenterHelpers.DomInstanceValueFieldHelper.OnFieldDescriptorChanged(Object sender, ChangedEventArgs changedEventArgs)
at Skyline.DataMiner.Utils.InteractiveAutomationScript.DropDown`1.RaiseResultEvents()
at Skyline.DataMiner.Utils.InteractiveAutomationScript.Dialog`1.RaiseResultEvents(UIResults uir)
at Skyline.DataMiner.Utils.InteractiveAutomationScript.Dialog`1.ShowInteractive()
at Skyline.DataMiner.Utils.InteractiveAutomationScript.InteractiveController.Run(IDialog startDialog)   at Script.Run(Engine engine)" (see comment for more details)
Any suggestion?
Ladan Razeghi [DevOps Catalyst] Selected answer as best 14th August 2023
Thomas Cauwelier [SLC] [DevOps Advocate] commented 28th April 2023
Hi Ladan,
I’m not sure if you still need the DomInstanceValueFieldDescriptor, but the new version with the fix is now available on the catalog.
https://catalog.dataminer.services/catalog/3195
The fix is available in version 10.3.3.4 & 10.2.8.5 depending on your DataMiner version.
Note, we discovered an issue with the installation process.
If the installation fails, try to upgrade DataMiner to version 10.2.10 or higher.
Ladan Razeghi [DevOps Catalyst] commented 28th April 2023
Hi Thomas, I’m using version 10.3.4.0 and still have problem with installation. Deployment fails and noting is added to information event to know why
Marieke Goethals [SLC] [DevOps Catalyst] commented 6th July 2023
I noticed that this question has been open for some time now. Can you confirm if you have found a solution, so we can mark this question as solved?
Marieke Goethals [SLC] [DevOps Catalyst]7.33K Posted 6th July 2023 1 Comment
The latest version, which should include all the necessary fixes, is available in the catalog here: Catalog (dataminer.services).
Ladan Razeghi [DevOps Catalyst] commented 18th July 2023
Hi Marieke
As mentioned in my previous comment, I couldn’t deploy version 10.3.4 and I wasn’t aware that new version is created. Thank you for the update. Today I could deploy 10.3.5 version. I’ll spend sometime this week to see if the problem is resolved or not. Best
You are viewing 1 out of 5 answers, click here to view all answers.
