Script Failure (Dom Editor) while using DomInstanceValueFieldDiscriptor
Solved4.26K views14th August 2023DOM DOM Editor
Ladan Razeghi [DevOps Catalyst]1.09K 25th April 2023 3 Comments
I'm using Dom Editor and while trying to link a field in one section definition to another section I receive this error.
Script Failure (Dom Editor): EXIT: "System.InvalidCastException: Unable to cast object of type 'Skyline.DataMiner.Utils.InteractiveAutomationScript.StackPanel' to type 'DOM_Editor_1.FieldDescriptor.Panels.DomInstanceValueFieldDescriptorPanel'.
at DOM_Editor_1.FieldDescriptor.PresenterHelpers.DomInstanceValueFieldHelper.OnFieldDescriptorChanged(Object sender, ChangedEventArgs changedEventArgs)
at Skyline.DataMiner.Utils.InteractiveAutomationScript.DropDown`1.RaiseResultEvents()
at Skyline.DataMiner.Utils.InteractiveAutomationScript.Dialog`1.RaiseResultEvents(UIResults uir)
at Skyline.DataMiner.Utils.InteractiveAutomationScript.Dialog`1.ShowInteractive()
at Skyline.DataMiner.Utils.InteractiveAutomationScript.InteractiveController.Run(IDialog startDialog)   at Script.Run(Engine engine)" (see comment for more details)
Any suggestion?
Ladan Razeghi [DevOps Catalyst] Selected answer as best 14th August 2023
Thomas Cauwelier [SLC] [DevOps Advocate] commented 28th April 2023
Hi Ladan,
I’m not sure if you still need the DomInstanceValueFieldDescriptor, but the new version with the fix is now available on the catalog.
https://catalog.dataminer.services/catalog/3195
The fix is available in version 10.3.3.4 & 10.2.8.5 depending on your DataMiner version.
Note, we discovered an issue with the installation process.
If the installation fails, try to upgrade DataMiner to version 10.2.10 or higher.
Ladan Razeghi [DevOps Catalyst] commented 28th April 2023
Hi Thomas, I’m using version 10.3.4.0 and still have problem with installation. Deployment fails and noting is added to information event to know why
Marieke Goethals [SLC] [DevOps Catalyst] commented 6th July 2023
I noticed that this question has been open for some time now. Can you confirm if you have found a solution, so we can mark this question as solved?
Martijn Vanallemeersch [SLC] [DevOps Member]953 Posted 25th April 2023 1 Comment
Hi Ladan, thanks for the clarification. What you need is a DOM instance field descriptor for your use case & not a DOM instance value field descriptor:
This is an example of something similar: Where we have workorders on the right & clients or organizations on the left. These are two different DOM modules/definitions which are linked together so on my workorder I have a field called customer/client which links towards my customer DOM module.
Hope this helps
Ladan Razeghi [DevOps Catalyst] Posted new comment 25th April 2023
Ladan Razeghi [DevOps Catalyst] commented 25th April 2023
Hi Martijn
Mine is not 2 DOMs. It’s one DOM called event-management which contains multiple section definitions which one is called work order and another on is call client and I need to see client names in one field of work order.
Do I still need to use the instance which you’re suggesting?
You are viewing 1 out of 5 answers, click here to view all answers.
