Script Does not contain GetDms
Solved2.17K views26th October 2024
Davor Joleski [DevOps Enabler]743 26th October 2024 0 Comments
HI guys this getdms var cant read it it saying
Severity Code Description Project File Line Suppression State Details
public class MaskElementDialog : Dialog
private readonly Label helloPapi;
private readonly Label elemPapi;
public MaskElementDialog(IEngine engine) : base(engine)
helloPapi = new Label($"Hi {engine.UserDisplayName} please select an elment to mask");
elemPapi = new Label("Eelemtn");
var getdms = engine.GetDms();
EelemntDropdown = new DropDown();
Error (active) CS1061 'IEngine' does not contain a definition for 'GetDms' and no accessible extension method 'GetDms' accepting a first argument of type 'IEngine' could be found (are you missing a using directive or an assembly reference?)
how to set it properly
Davor Joleski [DevOps Enabler] Answered question 26th October 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 26th October 2024 3 Comments
Hi Davor,
You will need to install the NuGet package: NuGet Gallery | Skyline.DataMiner.Core.DataMinerSystem.Automation 1.1.1.13
More information can be found in DataMiner Docs: Class library introduction | DataMiner Docs
Hope it helps.
Davor Joleski [DevOps Enabler] Posted new comment 26th October 2024
Davor Joleski [DevOps Enabler] commented 26th October 2024
Thanks alot Miguel
One more question Miguel ill send below
i’ve done that question too don’t need sorry
