Scheduling Alarm Template between 12:00 to 16:00 for example.
Solved1.02K views23rd January 2025alarm alarm template scheduling Specific time
Johan Godfrin [DevOps Advocate]110 5th September 2024 0 Comments
Hello Dojo,
Is it possible to make a schedule for a template alarm? We need the alarm template for an element to be active for only 4 hours during the day at specific times.
If this is possible, what is the best practice?
Simon Raine [SLC] [DevOps Member]2.08K Posted 5th September 2024 2 Comments
Hi Johan.
The possibilities to schedule an alarm template can be found here – Scheduling an alarm template | DataMiner Docs
Johan Godfrin [DevOps Advocate] commented 5th September 2024
Many thanks. I looked everywhere except this place
Simon Raine [SLC] [DevOps Member] commented 5th September 2024
No problem. Glad I could help.
