Scheduler runs an automation script (get “interaction is required to execute this script” error)
Solved2.43K views7th July 2023Automation script interactive Scheduler
9
Miao Miao408 13th January 2023 0 Comments
Hi
I setup a scheduler to run an automation script on hourly basis.
However, i got "interaction is required to execute this script" error when the scheduler tries to run the auto script.
I double checked the automation script and it seems doesn't have any showUI() function call.
The C# code in the auto script for debugging is engine.Log().
Thanks in advance.
Pawel Bochenek [DevOps Member]736 Posted 14th January 2023 1 Comment
Hi Miao,
In your staging environment, can you insert the following at the begining of the C# code:
engine.FindInteractiveClient("This is test only", 15);
When the script is executed, active clients will get a pop-up window with the option to attach to the script (you must have an active and open DM client window for the pop-up to appear). Click on the 'Attach' button. This will set the engine.IsInteractive = true, and you as the interactive user. This way you should be able to see what interaction is required by the script at run-time.
Note: This pop-up will only be displayed for 15 seconds and if no selection is made the script will assume 'Ignore' and continue to run.
Miao Miao Posted new comment 15th January 2023
Miao Miao commented 15th January 2023
thanks
