Scheduler runs an automation script (get “interaction is required to execute this script” error)
Solved2.38K views7th July 2023Automation script interactive Scheduler
9
Miao Miao408 13th January 2023 0 Comments
Hi
I setup a scheduler to run an automation script on hourly basis.
However, i got "interaction is required to execute this script" error when the scheduler tries to run the auto script.
I double checked the automation script and it seems doesn't have any showUI() function call.
The C# code in the auto script for debugging is engine.Log().
Thanks in advance.
Bert Buysschaert [SLC] [DevOps Advocate]5.31K Posted 13th January 2023 2 Comments
Hi Miao,
Does the script contain any commented-out line of code that has a .ShowUI() call? This will also incorrectly flag the script as requiring interaction. You can work around this by avoiding this string, e.g. rename to .Show---UI()
You can also verify this by opening the script .xml file located in C:\Skyline DataMiner\Scripts\ on the agent. The root XML tag contains an options attribute, for example <DMSScript options="272">. If these options are set to value 304 it has the interactive flag enabled (contains bit flag 0x0020).
Bert Buysschaert [SLC] [DevOps Advocate] commented 13th January 2023
Addendum: other calls that implicitly trigger the interactive flag are “.RunClientProgram()” and “.ShowProgress()”, as well as setting “engine.IsInteractive” explicitly.
Miao Miao commented 15th January 2023
thanks
