Saved filters option not visible for some users
Solved2.45K views12th July 2023Alarm Console Saved filters
Jan-Terje Larsen96 16th November 2022 0 Comments
One of our users are not able to select "Saved filters" in the filter-dropdown when creating a new tab in the alarm console.
In the below screenshot I would expect an option "Saved filters" after "View impact"
This is what I see with my user logged on:
Is there any rights-settings that enable/disable this feature?
Ive Herreman [SLC] [DevOps Enabler]14.71K Posted 16th November 2022 0 Comments
Hi Jan-Terje,
The saved filters option is only visible when there are saved filters accessible to the user.
If the system would contain only private filters, then the user will not see the "saved filters" option until the user creates a filter, or until a private or public filter is created in the system.
Ive Herreman [SLC] [DevOps Enabler] Answered question 16th November 2022
