Same driver for Harmonic RD9000 and Thomson RD4000?
Solved2.22K views18th July 2023Harmonic Thomson
Bart Reynaert [SLC] [DevOps Member]203 2nd November 2021 0 Comments
Question related to Harmonic's acquisition of Thomson Video Networks back in 2016:
Is the Harmonic RD9000 decoder driver compatible with the Thomson RD4000 decoder? In other words: Can the RD9000 driver be used to integrate the RD4000?
André Camões [SLC] [DevOps Advocate]575 Posted 2nd November 2021 0 Comments
Hi Bart
From a first glance, I would say not yet...
I'm running a simulation from Thomson Video Networks RD4000 against both RD4000 and RD9000 and, I cannot see the same data being displayed.
For your information, I'm considering these versions:
  • Thomson Video Networks RD4000 version 1.0.1.2
  • Harmonic RD9000 Decoder version  1.0.0.3
