Running DataMiner Automation Scripts as a User Instead of System
Solved1.34K views26th June 2025
Samson Fayoyiwa [DevOps Advocate]564 12th February 2025 4 Comments
Hello Dojo Community,
I have a C# automation script in DataMiner that backs up a specific file due to its operational sensitivity and frequent usage. The script executes successfully when scheduled via DataMiner but fails to complete the backup because:
  • The remote server only allows access from a specific user account and not from the SYSTEM account that DataMiner uses by default.
  • The file transfer to the remote server is denied due to permission restrictions.
 Is there a way to execute a DataMiner automation script under a specific user account instead of SYSTEM?
Samson Fayoyiwa [DevOps Advocate] Posted new comment 26th June 2025
Miguel Obregon [SLC] [DevOps Catalyst] commented 12th February 2025
Hi Samson,
Please could you elaborate the backup process? Are you storing the file in a network share folder? Is this remote server part of the DataMiner cluster?
Samson Fayoyiwa [DevOps Advocate] commented 12th February 2025
Hello Miguel,
Are you storing the file in a network share folder? Yes
Is this remote server part of the DataMiner cluster? No, it is outside the cluster
Marieke Goethals [SLC] [DevOps Catalyst] commented 26th June 2025
Hi Samson,
Samson Fayoyiwa [DevOps Advocate] commented 26th June 2025
Thanks just did
Felix Wesemeier [DevOps Catalyst]2.54K Posted 13th February 2025 0 Comments
Hi Samson,
as far as I know it is not possible to run the script as another user.
But inside your script you could impersonate another user.
Maybe this is a g0od starting point: Impersonating User in C# causes users to be removed on LDAP synchronization - DataMiner Dojo
WindowsIdentity.Impersonate Method (System.Security.Principal) | Microsoft Learn
Samson Fayoyiwa [DevOps Advocate] Selected answer as best 26th June 2025
