RSP 1200 Panel and Dataminer Integration
Solved2.13K views18th July 2024#riedel #cube #RSP
Motoki Orikasa [DevOps Member]86 15th October 2023 1 Comment
Hi All,
I have set up RSP and Dataminer, but the connection with RSP is "timeout" and I've set CPA App and NMOS App on RSP side to Enable, but it is still timeout....
please let me know if there is something I am missing in the settings.
Please advise.
Cheers,
Motoki
As this question has now been open for a long time and there has been no further reaction from you, I will now close it. If you do wish to investigate this further, feel free to post a new question or contact techsupport@skyline.be for assistance.
Miguel Obregon [SLC] [DevOps Catalyst]22.42K Posted 15th October 2023 2 Comments
Hi Motoki,
Checking the Driver Help of this connector, I see that you need to use the IP address of the DMA in the connections 'HTTP CONNECTION DATAMINER' and 'WEB SOCKET CONNECTION PRODUCER':
Hope it helps.
Motoki Orikasa [DevOps Member] commented 16th October 2023
Hi Miguel,
Thanks for the advice.
will try it later, and tell you the result!
Hi Miguel again,
hmm, i changed the HTTP connection dataminer/websocket dataminer connection, but it’s still timeout status… is there any something solution here?
