R&S PowerMeter NRP2, equipment configuration for integration with Dataminer.
Solved1.88K views5th October 2023#communication #NRP2 #PowerMeter #R&S configuration
Jardel Costa [DevOps Advocate]278 3rd May 2023 2 Comments
We are experiencing a communication problem with the R&S PowerMeter NRP2, does anyone have any tips or past experience with this equipment for DMA integration?
What do we need to test or configure on the element before trying to communicate between the equipment and the connector/driver?
Could you help me please?
Jardel Costa [DevOps Advocate] Selected answer as best 5th October 2023
Rene De Posada [SLC] [DevOps Advocate] commented 3rd May 2023
Hi Jardel, could you please provide the name of the connector you are trying to use?
Jardel Costa [DevOps Advocate] commented 10th May 2023
Hi Rene, I already tried with these 2 drivers/connectors:
https://catalog.dataminer.services/result/driver/5280
https://catalog.dataminer.services/result/driver/763
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.36K Posted 4th May 2023 3 Comments
Hi Jardel,
I am supposing this is the driver you are looking for ?
Catalog (dataminer.services)
If so, the element configuration is present in that page. Can you have a look and let me know ?
Hi Arun, I already tried with these 2 drivers/connectors:
What does sensor number mean? Model or Serial Number?
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 6th July 2023
Hi Jardel, in that case I believe this might require the development of a new driver from scratch. Do you have the device documentation that will help get started with the development ?
Jardel Costa [DevOps Advocate] commented 25th September 2023
Hi Arun, the Sphinx Squad solved the problem by changing communication from telnet to VISA.
Thank you for your attention.
