retrieve multiple polling ip’s from element through automation
Solved1.63K views14th July 2023pollingip redundant polling
hans sanders [DevOps Advocate]618 7th April 2022 0 Comments
In automation (C#) one can retrieve the ‘primary’ polling ip using the ‘dummy.PollingIP’ statement.
However this returns only the ‘primary’ polling ip.
Some protocols have multiple polling intrerfaces though (either for redundancy or to retrieve info from different targets).
Is there any (supported) way to retrive info on the additional polling nterfaces ?
Joey Vanhalst [SLC] [DevOps Advocate]2.17K Posted 7th April 2022 0 Comments
Hi Hans,
You can find the port info in the ElementInfo property:
var myElement = engine.FindElement("MyElement");
var myElementInfo = myElement.ElementInfo;
var mainPollingIp = myElementInfo.MainPort?.PollingIPAddress;
var otherPollingIps = myElementInfo.ExtraPorts?.Select(p => p.PollingIPAddress);
