Restarting Current Element from QAction
Solved694 views22nd July 2025protocol QAction 900001
Jose Araujo [DevOps Advocate]1.01K 21st July 2025 0 Comments
I would like to know if it is possible to restart the current element from within a QAction. Specifically, I want to evaluate a condition in the QAction, and if the condition is not met, restart the element so the evaluation can be performed again.
Thanks
Joey Vanhalst [SLC] [DevOps Advocate] Answered question 22nd July 2025
Joey Vanhalst [SLC] [DevOps Advocate]2.13K Posted 22nd July 2025 0 Comments
Can you elaborate the use case why you would like to restart the element? Depending on your use case, there might bet better alternatives than restarting the element.
