Restarting Current Element from QAction
Solved679 views22nd July 2025protocol QAction 900001
Jose Araujo [DevOps Advocate]1.01K 21st July 2025 0 Comments
I would like to know if it is possible to restart the current element from within a QAction. Specifically, I want to evaluate a condition in the QAction, and if the condition is not met, restart the element so the evaluation can be performed again.
Thanks
Joey Vanhalst [SLC] [DevOps Advocate] Answered question 22nd July 2025
Miguel Obregon [SLC] [DevOps Catalyst]22.20K Posted 21st July 2025 3 Comments
Hi Jose,
Having a look at the class library, the IDmsElement interface has a method to restart an element:
Method Restart | DataMiner Docs
Hope it helps.
Jose Araujo [DevOps Advocate] Posted new comment 21st July 2025
Jose Araujo [DevOps Advocate] commented 21st July 2025
Hi Miguel,
You have some example how can use this method.
Thanks
Miguel Obregon [SLC] [DevOps Catalyst] commented 21st July 2025
Hi Jose,
I could not find an example in DataMiner Docs for this specific, but I found one to create an element:
https://docs.dataminer.services/develop/devguide/ClassLibrary/ClassLibraryExamples.html
Basically, once you instantiate a IDms object, you could use the method GetElement (https://docs.dataminer.services/develop/api/types/Skyline.DataMiner.Core.DataMinerSystem.Common.IDms.GetElement.html) to retrieve a reference to the element. From there you can use the method 'Restart' to restart the element.
Hope it helps.
thanks !! this is helpful
