response using GetElementByNameMessage
Solved904 views21st April 2026
Juan Falcon518 20th April 2026 0 Comments
hello
how can i use the GetElementByNameMessage? i cant find the type to asing on the responde.
GetElementByNameMessage elementVariable = new GetElementByNameMessage();
elementVariable.ElementName = Name;
var responseGetElementy = _dms.SendMessage(elementVariable) as xxxxxxx;
exist a document or manual to uses message?
Thanks
Juan
Juan Falcon Selected answer as best 21st April 2026
Thomas Cauwelier [SLC] [DevOps Advocate]1.87K Posted 20th April 2026 5 Comments
Hi Juan,
The response is of type ElementInfoEventMessage (when sent via _dms.SendSingleResponseMessage, otherwise the response is DMSMessage[] containing a single ElementInfoEventMessage)
NOTE: SLNet messages are not guaranteed to have a stable API.
Consider using a better supported alternative: IDms.GetElement(string) from the dataminersystem library.
See: About the DataMinerSystem library
Juan Falcon commented 20th April 2026
Hi Thomas
How can i define the IDms object in GQI? in protocol i use protocol,GetDms()
Thanks
Gelber Mahecha [SLC] [DevOps Enabler] commented 20th April 2026
Hi Juan,
In a GQI, you can obtain a reference to IDms within the OnInit Method:
public OnInitOutputArgs OnInit(OnInitInputArgs args)
// Initialize the data source
// See: https://aka.dataminer.services/igqioninit-oninit
_dms = args.DMS.GetConnection().GetDms();
Thomas
on the public inInit the args.DMS has no contains "Getconnection()" could it be for version of libraries or have to install some one on Nuget?
Tom Waterbley [SLC] [DevOps Enabler] commented 21st April 2026
Hi Juan,
The GetConnection method was added in DataMiner 10.4.6/10.5.0, could it be that you're using an older version of the NuGet?
https://docs.dataminer.services/develop/devguide/GQI_Extensions/API_Reference/GQIDMS.html#iconnection-getconnection
Juan Falcon commented 21st April 2026
Thanks Tom, i update the Skyline.DataMiner.Files.SLAnalyticsTypes from the Nuget and works ok.
