Replication – Is it possible to access a Web Interface from a Replicated Element?
Solved3.81K views25th September 2020elements replication web interface
Bruno Nogueira [SLC]50 22nd September 2020 0 Comments
Is it possible to reach the Web Interface on a given Element card, when accessing it via a Replicated Element?
Thanks.
Bruno Nogueira [SLC] Selected answer as best 25th September 2020
Ben Vandenberghe [SLC] [DevOps Advocate]9.77K Posted 22nd September 2020 0 Comments
That will likely not work.  A replicated element receives the raw data for all of its parameters from another DataMiner System, where the source element is managed.  The raw data is reconstructed into a managed element based on the driver (i.e. for that reason the DataMiner System where you create the replicated element needs to have the proper driver).
If you open the replicated element, it will show a data display page with the web interface (because that is defined in the driver), but it will not load the webpage, because that is a combination of the polling IP of the element and the URL structure defined by the driver.  But it is a replicated element, so it does not have a polling IP address.  So therefore Cube will not be able to open the URL for the web interface of the element if you try that on a replicated element.
