Replacement of Notify(87) for connectors and pagination
Solved417 views14th October 2025
Rebecca Kelsall [DevOps Advocate]706 14th October 2025 0 Comments
I was in the process of investigating why a getting a remote elements table value was only bringing back information for the 1st page (on a table within pagination) when I noticed that notify protocol 87 looks to be deprecated.
What is the replacement for connectors? I've found the equivalent library for automation, do we use the same one?
Does the replacement have the same issue with only bringing back the first page?
Rebecca Kelsall [DevOps Advocate] Selected answer as best 14th October 2025
Laurens Moutton [SLC] [DevOps Enabler]9.61K Posted 14th October 2025 0 Comments
Using the class library is indeed a valid replacement for connectors.
By using the IDmsTable object (Skyline.DataMiner.Core.DataMinerSystem.Common) and calling the method GetData(), an object will be returned that contains the complete table content, even when pagination would be defined on the table. More info about the GetData method can be found here
Regards,
