Removing weather section
Solved2.48K views18th July 2023weather
Tiago Bento [SLC]20 10th August 2021 0 Comments
Hi Dojo Community,
Is there a way to disable the weather section in DataMiner 10.1?
Thanks in advance.
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 10th August 2021 0 Comments
Hi Tiago,
You can do this in the user settings under the cube tab.
There is a subsection "Welcome page", where the settings can be changed.
(note that in my screenshot the option is not shown, as the weather section has been removed in the latest DataMiner version).
Ive Herreman [SLC] [DevOps Enabler] Answered question 10th August 2021
