Removing weather section
Solved1.90K views18th July 2023weather
Tiago Bento [SLC]20 10th August 2021 0 Comments
Hi Dojo Community,
Is there a way to disable the weather section in DataMiner 10.1?
Thanks in advance.
Matthias Declerck [SLC] [DevOps Advocate]2.99K Posted 10th August 2021 0 Comments
More technical info:
– Weather section is a discontinued feature since 9.6.0 [CU5]. More info in RN 21592 and RN 21786.
– This was configurable with client settings. The setting is now always set to FALSE, yet it will still read the value of that setting.
You can check the user setting JSON file and search after ‘Cube.homepage.enabling.weather’.
Modify the correspondent value if you need to.
Ive Herreman [SLC] [DevOps Enabler]14.54K Posted 10th August 2021 0 Comments
Hi Tiago,
You can do this in the user settings under the cube tab.
There is a subsection “Welcome page”, where the settings can be changed.
(note that in my screenshot the option is not shown, as the weather section has been removed in the latest DataMiner version).
Ive Herreman [SLC] [DevOps Enabler] Answered question 10th August 2021
