Remote DMA connection from a protocol
Solved1.58K views28th August 2024connection driver remote dma
Manuel Gallardo [DevOps Advocate]811 2nd July 2024 1 Comment
What’s the best way to connect to a remote standalone DMA from a driver?
Common methods I’ve found only support remote DMAs that are in the same cluster by using the ID.
Is there another way besides web services?
Thanks in advance!
Manuel Gallardo [DevOps Advocate] Selected answer as best 28th August 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2024
Baptiste Pattyn [SLC] [DevOps Advocate]5.86K Posted 2nd July 2024 0 Comments
Hi
depending on your use case it would indeed be the WebAPIs or web services.
If you have a specific workflow in mind you can also look into User Defined APIs (User-Defined APIs | DataMiner Docs). This allows you to execute an automation script on a DMA. You can see this as a WebAPI call that you give a custom implementation.
With kind regards.
