Registering self-made connectors with Skyline
Solved1.36K views17th July 2023Connector DIS register registering
Jeroen Geldhof [SLC] [DevOps Enabler]5.49K 8th February 2022 0 Comments
Can you share a workflow with us how users can register their connectors to have them approved by Skyline, and and how they can get protocol metadata (Integration ID, …)?
https://help.dataminer.services/development/#t=DataMinerDevelopmentLibrary_Customer%2Fpart2CodingGuidelines%2FCODAdminMetadata%2FProtocol_metadata.htm
Should specific names be used, e.g. “CompanyName AppearTV xyz”, or is “AppearTV xyz” okay?
Jeroen Geldhof [SLC] [DevOps Enabler]5.49K Posted 8th February 2022 0 Comments
You can send an email to your DataMiner contact person to register the protocol entry and to provide you with the details to use in the protocol.
Just registering it with us will not validate the connector code.  To have it registered we don’t even need the code itself.
For having the connector validated by Skyline, engineering hours need to be purchased.
The name will indeed include the company name.  You can search the Catalog for “provided by” to find examples of how these are named.  https://catalog.dataminer.services/?q=provided%20by
