Refresh issue when switching between 2 web pages of the same driver.
Solved1.71K views18th November 2022Webpages
Frederic Anthierens [SLC] [DevOps Advocate]326 28th June 2021 0 Comments
Hi all,
Context:
The driver has 2 web pages:
- Matrix (: subpage of the website)
- Web Interface (: main page of the website)
When I open both pages for the first time, the webpages are loaded correctly (see Figure 1 and 2).
Figure 1: Matrix.
Figure 2: Web interface.
When I go back to the Matrix page (Matrix -> Web Interface -> Matrix), the page does not load anymore (see Figure 3).
Figure 3: Not loaded matrix page.
The URLs are defined via a stand-alone parameter (see Figure 4) and still contain the correct value/URL when the pages do not want to load anymore (see Figure 5).
Figure 4: Declaration web pages.
Figure 5: Content stand-alone parameters.
Finally I have checked and the web browser engine option of the page plugins in the system center, is set to Chromium.
If I close and re-open the element card, the web pages are loaded correctly but the refresh issue remains.
Question:
Do you have an idea what might be the cause or any guidelines how I can debug this issue and determine if it is protocol or software related?
Thanks in advance!
Frederic Anthierens [SLC] [DevOps Advocate] Selected answer as best 18th November 2022
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 18th November 2022 0 Comments
This indeed looks like a software issue, if it's still present on the latest DMA version i would send a DELT package including the elementdata and visio file to techsupport@skyline.be
