Reference SRM from Automation Script
Solved2.04K views2nd November 2022automation scipt SRM
Julio Riambau [SLC] [DevOps Member]302 28th October 2022 1 Comment
I’m referencing SLSRMLibrary.dll from an automation script.
When the dmapp is created and imported it will contain a reference to C:\Skyline DataMiner\ProtocolScripts\SLSRMLibrary.dll.
Could you please let me know which would be the procedure to correctly reference SRM in an automation script so that the dmapp contains the proper DLL reference?
Thanks in advance.
Julio Riambau [SLC] [DevOps Member] Selected answer as best 2nd November 2022
Julio Riambau [SLC] [DevOps Member] commented 31st October 2022
fixed by using the DLL Path attribute on the reference
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 2nd November 2022 0 Comments
Hi Julio,
In addition to the answer from Emmanuel
Emmanuel Dal [SLC] [DevOps Member]4.63K Posted 31st October 2022 2 Comments
Julio,
When installing or upgrading SRM, SLSRMLibrary is deployed under c:\Skyline DataMiner\Files\ directory.
Copying the DLL in a different directory will generate conflicts.
Emmanuel Dal [SLC] [DevOps Member] Edited comment 31st October 2022
Hi Emmanuel,
Thank you very much for the feedback.
I mean how should the visual studio solution be configured so that the reference on the generated dmapp points to
SLSRMLibrary.dll in Files instead of ProtocolScripts.
Example script: https://jenkins.skyline.be/blue/organizations/jenkins/SkylineAutomationA_SLCSandboxA_SLCSandbox_TestAutomationScript/detail/1.0.0.X/7/artifacts/
Emmanuel Dal [SLC] [DevOps Member] commented 31st October 2022
This can be done by adding a ‘DLL Path’ property to the SLSRMLibrary.dll you’ve referenced in your VS project.
The property value should be the full filename of the DLL ( c:\Skyline DataMiner\Files\SLSRMLibrary.dll )
