Redundant Polling in Dataminer: Is there a way to monitor the connection status of my driver?
Solved1.28K views2nd May 2025redundant polling
Chian Hao Aw [SLC] [DevOps Member]650 25th November 2024 0 Comments
I have an SNMP element running on redundant polling and the switchover is automatically handled within DataMiner. I was wondering if it was possible to monitor the connection the element is currently using, and if so how I could configure this on the element.
There was a question posted 3 years ago in similar vein to mine, so I'm wondering if this is a software feature that is available for us to use.
Thanks in advance
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 2nd May 2025
Laurens Moutton [SLC] [DevOps Enabler]9.96K Posted 26th November 2024 0 Comments
At this moment (DataMiner 10.4.12.0) there is no possibility to know which connection a group is using in case of redundant polling.
Regards,
