Redundancy groups config – switching logic : primary and backup possible as input for script?
Solved976 views30th October 2024redundancy groups
Justien Decuypere [SLC] [DevOps Member]322 30th October 2024 0 Comments
Is it possible to include the <primary> and <backup> elements as input parameters in the execution section of the switching logic?
Can you simply use these <primary> and <backup> elements as parameters?
For clarity, here's a hypothetical example (no actual data or script included yet):
Justien Decuypere [SLC] [DevOps Member] Selected answer as best 30th October 2024
Brent Alleweireldt [SLC]2.22K Posted 30th October 2024 1 Comment
Hi Justien,
This is possible. Scripts triggered by redundancy groups have some extra script parameters which contains this info (no extra configuration needed). The specific ones you need can be reached by doing  GetScriptParam(<ID>) in the automation script. iId 65010 for <primary> and 65011 for the <backup>
See DataMiner docs for more info on this and other included script parameters.
Justien Decuypere [SLC] [DevOps Member] commented 30th October 2024
Thank you Brent! That’s exactly what we need. 🙂
