RCA Level in 10.3, 10.4 and 10.5
Solved1.44K views31st July 2025adl2099 Alarm Console RCA RCA level Root Cause Analysis
Alberto De Luca [DevOps Enabler]5.75K 20th February 2025 2 Comments
Looking for some reference on the RCA level implemented in DM 10.3, 10.4, 10.5: any link to the relevant section of the documentation will be extremely helpful (admin guide, videos, exercises...)
Looking into what's currently possible, ideally to highlight specific alarms as the root cause of others:
e.g.: stormy weather conditions in element/protocol A, over signal degradation measured in element/protocol B ... specific linking to be built across elements... and so on.
Any steer will be helpful.
Thanks
Alberto De Luca [DevOps Enabler] Selected answer as best 31st July 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 26th June 2025
Alberto De Luca [DevOps Enabler] commented 31st July 2025
Will do Marieke, thanks – will repost if we need more info for the feature in 10.5
Felix Wesemeier [DevOps Catalyst]2.54K Posted 21st February 2025 3 Comments
Hi Alberto,
if I've no idea if there was anything new related to RCA coming from DM 10.3 onwards.
Is there something specific you are looking for?
But I remender this feature from older DM versions.
Here is a docs page with a lot of links related to it: Working with the Connectivity Editor | DataMiner Docs
Kind regards,
Felix
Felix Wesemeier [DevOps Catalyst] commented 21st February 2025
RCA & DCF: https://docs.dataminer.services/user-guide/Reference/DataMiner_Tools/SLNetClientTest_tool/SLNetClientTest_tool_advanced_procedures/SLNetClientTest_having_rca_chains_updated.html
https://docs.dataminer.services/user-guide/Advanced_Functionality/DCF/Defining_connectivity_chains/Automatically_generating_service_RCA_chains_based_on_connectivity.html
RCA in service templates: https://docs.dataminer.services/user-guide/Basic_Functionality/Services/Service_templates/Creating_a_service_template/ST_Specifying_root_cause_info.html
Alberto De Luca [DevOps Enabler] commented 6th March 2025
Thanks for these links, Felix – will check these asap
We're looking into ways to achieve some form of "Computer Assisted" root cause analysis, so that operators are facilitated in their task when many alarms are in console, e.g.: providing indication that alarms on device B are likely caused by an alarm on parameter "x" on device A.
Service definition may have to be created or updated if required for the RCA: please, do you know if the chains can be defined by manipulating XML files or is it required to use the "Connectivity Editor" in the Correlation UI?
I'm referring to these:
https://docs.dataminer.services/user-guide/Advanced_Functionality/DCF/Defining_connectivity_chains_in_XML_files.html
Most links will need converting now – Sharing the mapper here too, in case anyone else needs it:
http://docs.dataminer.services/xrefmap.yml
