Radio buttons in LCA
Solved392 views19th August 2025
Stefan Fransson [DevOps Advocate]221 14th August 2025 0 Comments
Hello,
are there any plans to add radio buttons as components in LCA?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th August 2025
Wout Mahieu [SLC] [DevOps Catalyst]11.40K Posted 14th August 2025 1 Comment
Hi Stefan,
Internally, we have talked about adding more input types to Dashboards & Low Code Apps. There are however no concrete plans yet for radio buttons. I suggest you create a feature suggestion so we can measure the interest for this new component.
Stefan Fransson [DevOps Advocate] commented 14th August 2025
Hi Wout, ok, thank you!
