Protocol won’t load into Dataminer
Solved2.02K views12th July 2023bug
Benjamin Hodžić [SLC] [DevOps Advocate]1.43K 9th September 2022 2 Comments
I'm using 10.2, when I try to import some dummy protocol for training on my localhost instance, by upload or copy-paste in the existing one, nothing happens.
Log:
2022/09/08 16:53:18.383|SLBPAManager.txt|SLNet.exe|.ctor|ERR|0|485|Error while constructing ExternalBpaProcess. (Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Failed to launch SLHelper (60s)
at SLHelperTypes.HelperWrapper.Launch(HandleMessageCallback messageCallback)
at Skyline.DataMiner.Net.BPA.ExternalBpaProcess..ctor(ILoggerWrapper logger)
2022/09/08 16:55:18.462|SLBPAManager.txt|SLNet.exe|CleanupHelperStatus|ERR|0|485|(Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Failed to launch SLHelper (60s)
at Skyline.DataMiner.Net.BPA.ExternalBpaProcess.CleanupHelperStatus()
Failed to cleanup external SLHelper process
Alberto De Luca [DevOps Enabler] commented 9th September 2022
Wondering what’s the “upload” GUI section you use – do you also get “.xml” only as the possible extension when right-clicking the protocol in the “Protocols & Templates” app?
Benjamin Hodžić [SLC] [DevOps Advocate] commented 9th September 2022
Yes, just the .xml file
But I actually got it to work by reinstalling dataminer
Benjamin Hodžić [SLC] [DevOps Advocate]1.43K Posted 9th September 2022 0 Comments
Fixed by reinstalling Dataminer.
