Process automation DOM UpdateField error
Solved1.34K views4th June 2024DOM process automation
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 1st March 2024 0 Comments
I need to update a DOM field using a method I’ve used before for other fields.
helper.UpdateField(“profileInstanceParameterName”, 0L);
The Profile parameter has the Value Remarks :  Reference to ‘process_automation/Channel/Channel/FlagDeleteDA’
In the logging I however get following error:
An issue occurred while instructing the create service action:  System.InvalidOperationException: ParameterEntry ….. doesn’t contain a reference to a DOM value at Skyline.DataMiner.DataMinerSolutions.ProcessAutomation.Manager.PaProfileLoadDomHelper.UpdateField[T[(String parameterName, T value) at PA.ProfileLoadDomTemplate.Script.Run(Engine engine)
If I look up the DOM instance I can see following:
FieldDescriptorName: FlagDeleteDA
FieldDescriptorID: ….
No FieldValue for FieldDescriptor found
It should be possible to set the field value if no value has been set before, right?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 4th June 2024
Peter Vanpoucke [SLC] [DevOps Advocate]1.24K Posted 1st March 2024 0 Comments
hi Jeroen
It looks like the profile instance that’s currently assigned to the activity doesn’t have a reference to field in the process DOM instance. Could you check if it does?
