Process automation – disable SetParameter verification
Solved1.92K views19th October 2023process automation
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 2nd October 2023 0 Comments
Is there a way to disable the SetParameter verification for the execution of scripts on process automation, similar like where we can disable the checkbox when executing an automation script manually?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th October 2023
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 2nd October 2023 0 Comments
Jeroen,
You can use the RuntimeFlags for that :
engine.SetFlag(RunTimeFlags.NoCheckingSets);
More info :Enum RunTimeFlags | DataMiner Docs
