Process Automation CRUD actions
Solved1.57K views25th January 2024crud DOM process automation
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 19th January 2024 0 Comments
I’d like to trigger a process automation when a DOM instance is updated.
However in the process automation we set flags on the DOM instance which are needed further in the process automation chain.  These sets in turn trigger the Update trigger, which in turn execute the script and do the flag sets.
How do we filter out that these flag-sets trigger the CRUD script?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 25th January 2024
André Rodrigues [SLC] [DevOps Advocate]884 Posted 23rd January 2024 0 Comments
Hi Jeroen,
The CRUD script will always be executed whenever those fields are updated.
To deal with this, maybe you could use an enum field descriptor with the name of the activities. That way, you’d be able to know at which point the CRUD script was executed.
