Problems with multiple set in tables parameters
Solved1.51K views6th April 2023
MAXIMILIANO FILHO [DevOps Enabler]1.10K 10th November 2021 0 Comments
Hello,
I'm having some problems when trying to set multiple parameters cells of a table. As you can see in the example below, I'm trying to set six parameters at once:
When I press any button to set them, the confirmation window shows correctly.
But, when I confirm the changes, it sets the parameters completely wrong, as you can see:
Could this be a protocol issue or a problem in the Dataminer version?
This is the DMA version: 10.1.0.0-10049-CU1
Thanks in advance.
Best Regards
MAXIMILIANO FILHO [DevOps Enabler] Selected answer as best 6th April 2023
Bruno Dias [SLC] [DevOps Member]2.39K Posted 10th November 2021 2 Comments
Hi Max,
Is it possible to share which protocol are you using for this issue?
Does it happen for other protocols? If not, I believe it can be a protocol issue.
MAXIMILIANO FILHO [DevOps Enabler] commented 11th November 2021
Hi Bruno,
It is a dummy protocol we’re developing for Sky. I couldn’t test with other protocols, because all the elements are in production. I’ll try to simulate an element using another protocol.
Hi Bruno,
I’ve found the issue. Some rows had the same display key, this was causing the errors. Thanks!
