Problems logging in to ziine
Solved2.40K views5th October 2022ziine
Edith Lansens [SLC] [DevOps Member]791 5th October 2022 0 Comments
I'm having trouble logging in to ziine. When I enter my username and password, I get an error. Does anyone know how to fix this?
Bert Buysschaert [SLC] [DevOps Advocate] Answered question 5th October 2022
Jens Vandewalle [SLC] [DevOps Advocate]10.01K Posted 5th October 2022 0 Comments
Hi Edith,
This issue is introduced this week and the team is looking to have this resolved asap. In the meantime, you can use one of below options to login.
Option 1: Log in using the latest client version
  1. When you see the Unknown user error screen, click on the OK button
  2. Fill in your username but leave the password blank
  3. Click on the connect button
  4. A popup window will appear that allows you to authenticate
Option 2: Log in using the server client version
  1. Open the Cube Desktop Application
  2. Right click on the Ziine Agent and select Connect using...
  3. Select the version provided by the server
Edith Lansens [SLC] [DevOps Member] Selected answer as best 5th October 2022
