Problems connecting my DataMiner System to the Cloud
Solved2.37K views20th January 2021cloud
Jens Vandewalle [SLC] [DevOps Advocate]10.00K 20th January 2021 0 Comments
Note that this feature is currently still in soft launch and subject to change.
I'm running DataMiner 10.1.1 and following the instructions on the help page to connect my DataMiner to the cloud. I get stuck in step 5 where clicking on the Get Global State button throws an exception.
I'm running ASP.NET Core Runtime 3.1.11 and NET Core Runtime 3.1.11.
What can be the problem?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 20th January 2021
Laurens Vergote [SLC] [DevOps Member]368 Posted 20th January 2021 1 Comment
Most likely the NATS  service you have installed is incorrectly configured in some way. Normally this should get configured automatically. In order to fully reset this configuration there are 2 possibilities:
Quick:
Send the following message to the DMA:
Skyline.DataMiner.Net.Apps.NATSCustodian.NatsCustodianResetNatsRequest with parameter "IsDistributed" == False
This will attempt to reset the NATS configuration to a working state.
With DMA Restart:
  1. Shut down DMA
  2. Remove the NATS and NAS service
    1. cmd> sc stop NATS
    2. cmd> sc delete NATS
    3. cmd> sc stop NAS
    4. cmd> sc delete NAS
  3. Remove the NATS folder (C:\Skyline DataMiner\NATS)
  4. Restart the DMA
When DataMiner is restarted it should automatically reinstall the NATS and NAS service and configure them correctly.
Jens Vandewalle [SLC] [DevOps Advocate] Posted new comment 1st February 2021
Jens Vandewalle [SLC] [DevOps Advocate] commented 1st February 2021
Executed the 2nd option and it worked. Thanks!
