Problem with displaying trends on the dashboard
Solved2.04K views30th January 2024
Jaroslaw Burtny [DevOps Member]756 26th January 2024 0 Comments
Hi ALL.
Why can't I display TRENDS for querying the table but for taken for the parameter table, I can ?
Is there anything I can change in the settings to do this?
The screen from QUERIES to Service table
The screen from table parameters SERVICE as below:
Where could the problem be?
Big tahnks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th January 2024
Robin Debel [SLC] [DevOps Advocate]2.36K Posted 26th January 2024 1 Comment
Hi Jarek.
The simple answer is it is not possible to do this in the GQI Table.
You could however feed the selected row of the GQI table to a parameter table and in this way keep the ability to click open its graph.
Another posibility is to feed the selected row to a line chart.
Robin Debel [SLC] [DevOps Advocate] Edited answer 29th January 2024
Jaroslaw Burtny [DevOps Member] commented 26th January 2024
Hi Robin.
Can you show me how to do this as this is my first step?
Br.
Jarek
