Problem with deleting table edges
Solved986 views22nd April 2024
Jaroslaw Burtny [DevOps Member]756 2nd February 2024 0 Comments
Hi ALL.
How can I  remove display edges of the table if I use LAYOUT style like transparent and how can I make auto-size the displayed table ?
Big tahnks for help.
Br,
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 22nd April 2024
Steve Purcell [SLC] [DevOps Advocate]2.37K Posted 6th February 2024 0 Comments
Hi Jarek,
Not sure if this will provide all you are asking for, however, if you select the dashboard background, then select settings.  Under Dashboard configuration you can choose the enable ‘Allow components to shift’ and ‘Fit to view’, which may help with what you are looking for.  After these are enabled, resize the display shapes to where you want them.
