Problem script executing kata 55#
Solved1.05K views7th February 2025
Davor Joleski [DevOps Enabler]743 7th February 2025 0 Comments
HI i have problem with script kata 55 execute it's falling what could be the problem
Davor Joleski [DevOps Enabler] Selected answer as best 7th February 2025
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 7th February 2025 3 Comments
Hi Davor,
Can you check the protocols & templates module in cube, and verify if the "Generic Data Simulator" protocol, has an alarm template named "Alarm_Default" against the production version?
Davor Joleski [DevOps Enabler] commented 7th February 2025
Hi Ive on production version there is nothing but on 1.0.0.2 is alarm default
Ive Herreman [SLC] [DevOps Enabler] commented 7th February 2025
Can you duplicate the template (or create a new one) with the name "Alarm_default" on the production version?
Thanks it worked now i changed also for template 🙂
