Problem low_code lagging in edit mode
Solved1.15K views25th October 2024
Davor Joleski [DevOps Enabler]743 23rd October 2024 2 Comments
Hi guys i have problem in Low_code in review mode is good everything ,  in edit mode is so slow and at the end is crashing.Any way to fix the cache or something solution tips thank you
Nobody Toopakic [DevOps Advocate] Answered question 25th October 2024
Wout Mahieu [SLC] [DevOps Catalyst] commented 24th October 2024
Hi Davor, I’m not sure what could be going wrong with your LCA from this limited context. Can you explain a bit more about the app/components that you use?
Davor Joleski [DevOps Enabler] commented 24th October 2024
Hi Wout thanks for respond ill send you pictures below
Davor Joleski [DevOps Enabler]743 Posted 24th October 2024 2 Comments
this is happenig in edit mode loading loading and is freezing and after that crash on the next picture..
Davor Joleski [DevOps Enabler] Selected answer as best 24th October 2024
As i find out that i have a big data in behind, and its crashing becouse of it i stop that and now is lagging just, any solution how can be fixed ?
Hi Davor, looking at the provided screenshots, it indeed looks like the browser runs out of memory. This can have a lot of different reasons, which can be difficult to pinpoint. I suggest you get in touch with tech support to look further into this issue.
