Problem initializing parameters in menu GENERAL PARAMETERS ( Framework Connectivity)
Solved2.34K views23rd January 2024
Jaroslaw Burtny [DevOps Member]756 18th January 2024 0 Comments
Hi All.
The problem with DCF connection in dashboards is probably because I cannot initiate connections in menu GENERAL PARAMETERS ( Framework Connectivity)  for Element AppearTV X10 and BridgeTech VB 2220 as below
But in Element TMux Ateme I see these connection as below :
How can I takes these parameters from Menu GENERAL PARAMETERS --> Framework Connectivity correctly on DMA and next to dashboard for DCF connection.
Are these parameters initialized automatically by the driver or can I set them?
I see them not initialized for some elements
Is it a problem with  the driver? something needs to be marked in driver or a bad driver for elements?
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd January 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.81K Posted 19th January 2024 1 Comment
Hi Jarek,
I created a small mockup that imitates your current setup. Checking your screenshots, I believe you will need to update the source and destination for your edges:
Hope it helps!
Jaroslaw Burtny [DevOps Member] commented 19th January 2024
Hi Miguel.
Yes, You’re right, it works.
Br.
Jarek
