Problem initializing parameters in menu GENERAL PARAMETERS ( Framework Connectivity)
Solved2.23K views23rd January 2024
Jaroslaw Burtny [DevOps Member]756 18th January 2024 0 Comments
Hi All.
The problem with DCF connection in dashboards is probably because I cannot initiate connections in menu GENERAL PARAMETERS ( Framework Connectivity)  for Element AppearTV X10 and BridgeTech VB 2220 as below
But in Element TMux Ateme I see these connection as below :
How can I takes these parameters from Menu GENERAL PARAMETERS –> Framework Connectivity correctly on DMA and next to dashboard for DCF connection.
Are these parameters initialized automatically by the driver or can I set them?
I see them not initialized for some elements
Is it a problem with  the driver? something needs to be marked in driver or a bad driver for elements?
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd January 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 19th January 2024 1 Comment
Hi Jarek,
I created a small mockup that imitates your current setup. Checking your screenshots, I believe you will need to update the source and destination for your edges:
Hope it helps!
Jaroslaw Burtny [DevOps Member] commented 19th January 2024
Hi Miguel.
Yes, You’re right, it works.
Br.
Jarek
João Severino [SLC] [DevOps Enabler]14.78K Posted 19th January 2024 1 Comment
I cannot say with certainty if what you are experiencing is an issue or not with the information available but I can give you some pointers on things you can check to be sure and possibly make your Dashboards display the info you want.
DCFs are a way of representing in your DataMiner elements the connectivity between your devices or software products and, in some cases, the connector/driver is capable of determining such connectivity and it will populate those connections tables.
However, this is not always the case or it may be capable of only doing partially the connectivity.
In those cases, operators can manually configure DCF connectivity by going into an element’s properties and performing the configurations in the Connectivity tab as displayed in the screenshot below
Alternatively and to avoid a lot of manual configuration you can consider looking into IDP Connectivity Discovery to automate this process
Jaroslaw Burtny [DevOps Member] Posted new comment 19th January 2024
Hi Joao.
I configures the connection between elements as below.
Please read below
Jaroslaw Burtny [DevOps Member]756 Posted 19th January 2024 2 Comments
Hi Joao.
I configured the connections manually as below.
External connection TMUX –> AppearTV  FROm TMUX site:
External connection APPEARTV –> TMUX  FROm APPEARTV site
It seems that everything is fine due to external connections..
I can’t display garf connections between nodes, still
below are my settings for DCF connection
It seems OK but I can’t see the graphical connection between the nodes
Where could the problem be?
Big thanks for help,
Br.
Jarek
João Severino [SLC] [DevOps Enabler] commented 19th January 2024
At first glance, everything seems to be correct but maybe someone with more experience in the Node Edge Graph can provide input on this.
Br.
Jarek
