Preserving alarm audio alert settings when saving alarm tabs into a workspace
Solved1.78K views11th July 2023alarms Audio
John Armstrong10 4th January 2022 0 Comments
Hello Dojo.
When saving alarm tabs into a desk workspace complete with audio settings, the audio settings (e.g. wav files assigned to an alarm tab) do not appear to be remembered as part of the save process. I'm unsure at the moment whether this is by design or whether it is a limitation which needs addressing.
Ideally, we want the filtered alarm tabs and all audio alert settings to be saved into a desk workspace so we can enable everything relevant to a desk to be recalled via a workspace selection.
The other apparent alternative is manually creating the alarm tabs with audio settings in the bottom 'pop-up' console on each desk login but as these are not consciously 'saved', there is a possibility they could be lost.
Can anyone with experience of setting up audible alarm alerts advise?
Many thanks.
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 5th January 2022 0 Comments
Hi John,
There is an issue with saving an alarm tab with an audible alert in a workspace. We will look for a fix for this. Unfortunately there is no workaround for this problem.
