Preprocessor #defineon a C# automation script
Solved1.53K views19th July 2023
Henri Martins [DevOps Advocate]906 28th June 2023 0 Comments
Hi.
I want to use preprocessor instruction "#define DEBUG" as first instruction on a C# automation script
But when I clic validate, I've got one error: "Cannot define/undefine preprocessor symbols after token in file".
I don't understand what is the problem. What is the token, it's talking about?
Better how could I resolve it without running allways instructions like I've seen in others questions on DOJO.
Thanks
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 28th June 2023 2 Comments
Hi Henri,
You must make sure the #define DEBUG is the very first line of code in your script.
e.g. the code below validates just fine:
Ive Herreman [SLC] [DevOps Enabler] Posted new comment 28th June 2023
Henri Martins [DevOps Advocate] commented 28th June 2023
The “#define DEBUG” is on top of script, on first line.
The error message is always here.
Ive Herreman [SLC] [DevOps Enabler] commented 28th June 2023
Would you be able to share a screenshot of your automation script (or a link to a Git repo)?
